ab7oh's avatar
ab7oh
2 meter / 440 (70cm) Ground independent Antenna
The Comet SBB-5NMO dual band is a 2 meter and 440 MHz mobile antenna. It is a 1/2 wave on 2 meters providing 3 dB gain and a 2 5/8 wave on 440 MHz providing 5.5 dB gain. VSWR 1.5 : 1 or less. This antenna can handle up to 120 watts. I installed this antenna on my Motor Home because it is ground independent. It had 1.3 : 1 or less on both bands.
  • Bill.Winegard wrote:
    Ham radio something I am guessing?
    You guessed correctly !!
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Good Guess...Mine is a Diamond. Same basic specs.
    That is the equivalent to a Diamond NR-770RA (NMO mount) and NR-770HA (UHF mount) antenna which is also radialess (doesn't require a ground plane).
    While they will work as radialess, I have found that they tend to work much better for distance if you DO provide radials. Doesn't take much a couple feet of wire or even a piece of sheet metal.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: Feb 25, 2018
