TenOC's avatar
TenOC
Nomad
Apr 08, 2015
300 feet of Underground Cat6 ???
At my long-term parking location I need to run a 300 foot Ethernet cable for my internet connection. I will be using Cat6 unshielded full copper underground cable. Question.
1. Since only 1/2 of the wires (4 of the 8) are used, would I gain any advantage by parallel connecting the unused wired with the used one? For example the Green and Orange as one and the blue and brown as the second. The thought is that this would cut the resistance (drop) in half.
2. I am going to be using underground (non gel) cable - I could not find gel filled Cat6 cable. Is there any advantage in putting it in 1/2 plastic conduit?
  • RoyB wrote:
    ---snip---
    CAT5 -CAT6 cables unlike RG cables can be run for very long distances without much degrading of the signals.
    Not true.. And its actually worse
    Google ''max length of Ethernet cable".
    While coax loses signal the longer the run, so does ethernet. And when it hits its theroetical limit, collisions take over and nothing works.
  • RoyB's avatar
    RoyB
    Explorer II
    I solved that problem here by using a WIRELESS WIFI Modem/Router setup...
    My ROUTER here covers my whole house and back yard area rather well...
    All of this wireless WIFI item can be secured as far as keeping others from using it...
  • As you probably know, there is a specific twist to CAT6 cable to keep out external interfearence as well as crosstalk. Since at 300' you are already at the pushing the best engineering practices length without a repeater, Its possible that you 'might' make the situation worse by grabbing the wrong parallel pairs. If lucky, you might fix the attenuation, but now you start running into packet collisions again possibly made worse by playing with the twist.
    If this were me I think I would invest in a couple of 5.8GHz microwave units if you have line of sight . Also, if the router has WiFi built-in, certinally the cheaper route is to look at external gain antennas at the coach to see if you can pick it up direct.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 11, 2025
