covetsthesun's avatar
covetsthesun
32bit vs 64bit machines
Ok...another dumb question before I either upgrade current computer or go new. Decided this should be separate from my other post.
Currently have a 2008 HP Pavillion Desktop running Vista Home Premium. It's a 32bit machine. Replaced the hard drive about 3 years ago. Geeks are telling me to get new... I'm dragging my feet.
What is the real difference between 32bit and 64 bit machines?
thx
cts
  • I worked in the computer industry during the transition from 16-bit to 32-bit. The biggest difference I saw then was it allowed for more lower skilled programmers to develop highly inefficient code that required the larger address space. Some of that still holds true for the 32-bit to 64-bit transition, although the more sophisticated Operating Systems and complex, fancy graphical interfaces consume a lot more address space all by themselves. Thankfully the HW engineers have been able to keep pace with the SW engineers and improve computer speeds to make up for less efficient SW.
    So one of the main advantages of moving up to 64-bit systems is there will be a larger universe of software available to use, and most 64-bit OSes will support and run software written for 32-bit as well.
  • The most evident difference is the amount of memory (RAM) the system will support. 32bit are limited to 4GB, 64bit have a considerably higher limit in theory, but in practice 32GB is most common for desktops
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Feb 07, 2026
