dan-nickie
Sep 07, 2013Explorer II
titleman wrote:
Thanks Dan-Nickie. Actually then I will not be using the satellite cable to the BR as I will receive Sat. signal over the same cable I receive cable/ant on because it comes from the Video Switch which is connected to the satellite and when I have the BR switch on satellite the cable/ant is off. Is that correct? Very confusing but hopefully I am learning a little. I am going to connect everything up as Bob said and maybe I can get this all wrapped up successfully.
Thanks again. Joe
I think you have it.
Just need to find the Ant/Cable setting in your BR TV Menu.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 19, 2026
