FlatBroke
Sep 08, 2013Explorer II
titleman wrote:
One more question before hook this all up. Looks like to me I will have to either have the Ant/Cable connected to the TV or the Sat.cable as the TV has on one connection. Does this mean I will have to undo the cable and connect to the satellite each time I want to change signals or is there some kind of switch that I could use to keep from having to swap connections?
I just went through all that(only one cable for ant/cable/sat)in the bedroom. I put an A/B switch at the Winegard center and an A/B switch at the bed room TV for the same cable, then distribute the cables to the correct locations. This will work because the distribution center has the ANT. power supply. Draw out a simple diagram on paper and it will help. I did and it worked!
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 19, 2026
