titleman's avatar
titleman
A Little Hookup Help....Please
I realize this is a very simple operation for most of you folks, but for an old man that is about 10 steps behind when it comes to something like this, it is very frustrating.
I have a Winegard Video Distribution Center that I would like to use in my system so as to have Sat/Ant/cable signals at all three TV locations. I use a Winegard Carryout satellite dish so am not interested in HD at this point as it will not provide a HD signal.
In the LR there are two plates on the wall. One with two coax ports for satellite and the other is a Jensen power supply plate which has one coax port, a 12V receptacle, a fuse and a cab/off/ant switch on the front. Connected to the back of this plate are cables labeled ANT/IN, CABLE/IN and TV2/OUT along with 12V power lines. There is also another coax coming to the switch but not connected. It is labeled Radio/Out.
In the BR there are two wall plates. One with one coax port for sat. and the other with a 12V receptacle and one coax port for ant/cable.
In the Basement there are two plates with one coax port each.
The instructions for the Video Center say to disconnect the Ant/In cable from the back of the Power supply plate and connect it directly to the From/Ant on the Video Center and then to run a 12V cable from the power supply plate to the connection on the Video Center.
Then I will connect a coax cable from the "To Main TV" on the VC to the Antenna connection on the main TV. Then a coax cable from "To Second TV" on the VC to the coax connection on the power supply plate. FIRST QUESTION. does this also provide signal to the basement TV? Then I will connect a coax cable from the Sat/In on the wall plate to the Sat/IN on the Satellite Recv. QUESTION. How does park cable signal get to the VC? There is not but one coax port on the power supply plate where the park cable is connected and that has already been used for the antenna cable.
Bottom Line. I think I can handle the satellite part okay, but getting the cable and antenna to all three locations has me confused. If anyone can give me any advice or tell me where I can get some drawings that might help, I would very much appreciate it.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Feb 27, 2026
