myredracer's avatar
myredracer
Explorer II
Apr 17, 2019
AA battery life
Just a bit of a rant. :(
I have an SLR camera that I use a lot, mostly for documenting restoration of 2 cars I've been working on for a while. I use ordinary AA batteries and not rechargeable ones and normally get a month or two out of them, and I use the flash often.
Put new "super heavy duty" ones in the other day. Lasted about a week for just a few pics. What the heck. I tested the old batteries with a voltmeter first before tossing them to see if one or all needed replacing and also checked the new ones which showed they were good.
Then I looked at the package. A little hard to read maybe, but it says "ideal for low drain devices". Huh?
I know there's no need to pay for overpriced Duracell or Energizer as they're pretty much all built the same way. But a week out of something labeled "super heavy duty" ain't very good.
  • DW loves to shop in dollar stores. Worse, she's an accountant and cheap is always best. :( I'm sure that's where she would've got them.
    I just have to laugh at the "super heavy duty" labeling and then "ideal for low drain devices" in small print in the corner, both on the front of the package. :R
    I saw a comparison of alkaline batteries (consumer reports?) a few years ago that concluded there was little difference between most brands & prices so spending more $$ doesn't necessarily mean longer life.
    I'll check out lithium ones.
  • I've always had excellent life from the Energizer Ultimate Lithium batteries in my electronics. Pricey but worth it.
  • Just once. Spend the money for the Energizer Ultimate Lithium Batteries. Once you see how much longer they last, you will realize they are cheaper than a dozen cheap batteries.
  • If you are near a Costco go buy their jumbo pack of Kirkland batteries.
  • those sunbeam batteries are carbon-zink not alkiline that i am sure the camera maker recommends as a minimum. they sell those sunbeam batteries for $1.00 at the dollar stores like it says there for low draw devices. as a note i have had bad luck with duracell batteries leaking in many devices haven't had that problem with other brands so now i make sure i remove them from any device that will not be used regularly.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Nov 18, 2025
