timjet's avatar
timjet
Adding a Wingman UHF TV antenna
I may have screwed up. I thought I had a Winegard Batwing antenna and bought a Winegard Wingman intending to improve UHF reception and a Winegard Sensar Pro TV signal strength meter.
When I got the coach home I found out that I have a Braund Concord 90 Electric Antenna.
Is it possible to use the Wingman and Sensar Pro with the Concord antenna?
  • I'm the OP. I talked to Fleetwood and got a schematic and found out the unit that I'm replacing with the SensarPro has a booster in it. According to Winegard the SensarPro also has a booster in it, so it should work.
  • Then it is likely not the Concorde. That antenna is a powered raise/lower antenna that has a gold colored stretched oval shape and I think the wings were silver. That antenna does not have an amp inside the antenna housing.
  • Then it is not the Braund Concorde. That antenna is a powered raise/lower antenna that has a gold colored stretched oval shape and I think the wings were silver. That antenna does not have an amp inside the antenna housing.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
