rsdata's avatar
rsdata
Aiming Slimline SL3 SWM dish
I took the plunge and will be taking my DTV receiver with me. I purchased a duplicate dish. I have the new dish setup within a few yards of the house mounted dish so I could reference the new with the old. It took me about 3 hours to be able to get a signal with the new dish setup. I finally twisted the dish a tiny amount and the transmission finally popped up on the screen.
I was wondering if someone could steer me toward an inexpensive sat signal meter that I could hook up to the SWM splitter. I am hoping that by hooking up the meter I might be able to peak the signal easier by having immeadiate feedback at the dish location.
I have read that after doing it 10 times you will be a "pro" at pointing the dish... well... I'm one tenth the way to being a pro!
  • thx so far for the comments, but I am not seeing an answer to my question so let me restate...
    I am looking for a recommendation for an inexpensive sat peaking meter, something cheaper than a pro model, but also something that will work for my application.
    I am using an SL3 SWM Slimline dish. this is a single cable that requires a 21 V power insertion module between the receiver and the LNB
    I have a good tripod and my mast is level and plumb (I got that part).
    I want to be able to see instant feedback with a meter at the dish without using the TV and receiver to peak the dish signal.
    I am anticipating a hookup like the diagram below. I use the SWM splitter because the power insertion is 21V and I see that most meters are designated for 13-18 volts. I may try to power the meter with two (V batteries is series.
    upload pics">diagram here
    Since I cannot preview if the image will show above, I will just hope it does and post.
    Thanks again for your reply.
  • I agree a good surveyors style tripod that lets you level perfectly is your best friend.
    Dishpointer is great.
  • You can purchase several - I know Radio Shack has one, but I didn't like it.
    I put Satellite AR app on my cell phone and it works great! It will get me in the right direction and I can then tune it in, but if I'm having trouble, at dusk, if it's not cloudy, you can see the satellite and fine tune it even more.
  • The best thing you could do for yourself is go to www.tv4rv.com and purchase their heavy duty tripod system. This will make everything so simple for you.
    Bruce
  • I found using a meter to be more of a hindrance than a help.
    There's already a good video meter on your TV, and you'll never shoot the wrong sat. Problem is, no beeps. Sooo.. I use a Swift Hitch camera to 'see' the TV screen from outside.
    I get the settings from either the zip code, or dishpointer.com, and using a boy scout compass, can usually do it pretty quickly.
    But yeah, the first dozen times will be a learning curve, for sure. I hope you have a good, solid, stable tripod, because that's about 90% of being able to aim a Slimline.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,794 PostsLatest Activity: Mar 07, 2025
