ronfisherman
Nov 22, 2008Moderator
pulsar wrote:
Let's note here that your TV will be set to channel 3 and the converter box will be used to change the channels. It is the converter box that has the digital tuner. (All STB’s also have analog Video and Stereo Audio outputs that can feed an external V/A input on a vast majority of analog receivers.)
A note about TV channel.
The converts that I have installed use either channel 3 or 4. Depending on where switch on rear of converter is set. Others switch the channel during setup.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
