valhalla360
Oct 23, 2015Navigator
Possibly fine but you need more info:
- The TV should have a wattage rating on the back. You need to provide an inverter that at least matches that. If you are running any other a/c loads, you need to account for those also.
- Preferably the inverter should be a pure sine wave type or at least a modified sine wave or it could fry your electronics.
- Short thick wires are good but probably not critical if you are running just a small TV drawing maybe 60watts. Ideally, the inverter should be close to the batteries. The lower the voltage the more wiring length is an issue, so you want the 12v wiring to be short. Of course, that is less convienent for turning the inverter on and off. But for 4-5amps for a small TV it's not really critical.
- How big is your battery bank? A single starting battery and 4-5hrs of TV may leave you with a dead battery in the morning, particularly if the battery is getting old. You may want to consider a seperate house battery bank with deep cycle batteries but how big depends on what else you want to run off battery power.
- How many days will you sit in one spot watching TV? If you travel every day and some days are spent in a park with electricity, it's less of an issue. If you park for 4-5days, the suggestion to set up a solar system starts making more sense.
Search the site for similar threads. There is a lot of info already out there.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
