wa8yxm
Oct 26, 2015Explorer III
Advise; Mount inverter in the compartment NEXT to where the batteries live (not in the same air space) Use wire at least one size larger than the inverter maker recommends Tape the positive and negative wires side by side (Bundle) for as much of the run as possible.. Connect DIRECT to the battery via a proper size fuse (As recommended by inverter maker) do not run through disconnect switches of any kind.
That is all I can give you. Source: Xantrex customer support years ago + Experience.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
