- p220sigmanExplorerI agree. Unless there was a problem with the original routing, why reinvent the wheel? You likely can use the old cable to pull the new one through the firewall. I would run from the camera to the front, that way if you have excess cable, it can be tied up under the dash out of the way.
- Cobra21ExplorerI would probably follow the frame as it was before too. On my C, I was able to run my lead all the way down the heat duct system into my rear kitchen cabinets and to the outside for the camera. Has worked great like this for 7 years now.
Brian - Sam_SpadeExplorer
akaPedro wrote:
I bought a new wired system.
That might have been a tactical mistake.
Both used RVs I've had came new with a wired system which had failed. Both were replaced with wireless units that perform just fine.
If you can still return the wired system for a refund, you might want to re-think your plan. - downtheroadExplorerWhen I installed mine I started at the camera end. If I were doing it all over again I would just follow the path of the old cable. Use zip ties to secure it along the way.
Good luck with the project.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
