- GdetrailerExplorer IIILooks like I am the right track..
Read info here
Folks using MS "One Drive" will also experience the same issue..
Acutally good to know, have been planning to stand up a website devoted to my Antique Vehicles and was planning to use Google drive to handle photo storage.. Have a rough website on a thumb drive that is a collaboration between myself and my DD (she needed to build a website for one of her Graphics Arts classes).. - AsheGuyExplorer
BradW wrote:
https://photos.google.com/photo/AF1QipO2g3ya2X9_fySA-Mmrumc2QMTNWZbaxUmHaOyO
The google photo image link dose not work. The clickable google photo link does work.
In spite of the many complicated solutions suggested here for putting a photo in a post, it's not that complicated. The simplest way is to use the RV.NET provided Photo Post & Upload website that properly sizes the photo and provides a link to copy and past here (Example):
The other way is to use the RV.Net link icon
at the top of the posting window to link to any photo hosting site to display your photo(s). This example uses a link provided by Google Photos (using Google Drive just complicates the process) to an "Album" with one photo. Example: Sunrise - GdetrailerExplorer III
2oldman wrote:
Seems pretty complicated.. for now. I put a picture on ImageEvent, I grab the url, paste, done.
For pictures only I typically just use the "PhotoPosting Is Great" app that 1492 setup for the forum..
Never really tried direct pictures from Google drive as most of what I have shared I did in a PDF file.
What I have figured out is Google drive is "anonymizing" (hiding) the actual URL file name so the link does not have the proper jpg or picture file extension that the forum software is expecting..
Not sure if that can be changed..
Example is this link..
https://drive.google.com/file/d/1j-nCvW37Dx7QALJsn_113_NDYREZ8Wkq/view?usp=sharing
The only way I can figure out how to fix that is to make it a clickable link like THIS LINK
From that link it opens up a Google app which opens the photo.
For general pictures that you don't need in some album you can use Rv.net photo posting is great setup by member 1492. You can save the links and copy them into a word doc for future use.
that app adds in the proper format the forum needs so you can just paste into your forum posting. - 2oldmanExplorer IISeems pretty complicated.. for now. I put a picture on ImageEvent, I grab the url, paste, done.
Wants me to verify who I am..
You need to go to advanced settings and adjust the settings to not require login or password.. Default is most likely requiring a login.
Not sure if you get the same screens, I had saved this pix yrs ago, you should see an advanced setting on the bottom left of the box..
Once you have the access settings set to no password or login required you can then get the shareable URL link.
Should also note, you missed filling in the height when you attempted to post the photo, you will need to fill in both height and width when you use that option. - GdetrailerExplorer IIIRV net photo posting link step 1
Step 2
Just a note, those photos above I used the Photo hosting app provided by 1492 which automatically adds in proper img formating for the forum not my Google drive, I often will place one and done photos online by using that app..
You can of course save the links generated by the hosting app in a word doc or notepad doc for future needs if you like. - GdetrailerExplorer III
2oldman wrote:
Thanks, but I mean display it on here sans links. 1492 did it but I'll be darned if I can figure out how.
When you generate the hot link in Google drive, you need to copy the entire shareable URL hot link for that photo to the clipboard.
FOR PICTURES ONLY! Once you have the URL link, you use the advanced posting editor and hit the little yellow square box which looks like a mountain scene with a sun..
Paste the URL you copied from the Google drive there and make sure you set the width and height to no more than the max allowed on the forum (500 Wide by 100 high I believe)..
The trick here is getting your folder on Google drive setup as sharing without password or login required.. Only put items in that folder that you don't mind having shared.
I believe there is a setting for Read only on the folder that you might wish to enable if it is not by default, otherwise those items will be editable and possibly deleted..
You can also create a shareable hotlink to the folder and when you give that link all items in that folder can be viewed (sort of like a "photo album" of sorts but not sorted and no captions).
Been a while since I setup a shared folder so memory is a bit fuzzy and if all else fails, just do a search on how to setup a shared folder on Google drive.. I think that is how I figured it out.
Some of the terminology they use is confusing..
I might also add, to make things easy on my side and so I don't always have to open Google drive to get a link in the future, I create a document in Word or even notepad and paste that link from the clipboard into that document with a note of what that link is for. Save the document and now I have a quick reference of those shared docs. - BradWExplorer II
The google photo image link dose not work. The clickable google photo link does work. - 2oldmanExplorer IIThanks, but I mean display it on here sans links. 1492 did it but I'll be darned if I can figure out how.
2oldman wrote:
BobsYourUncle wrote:
See if you can display a google image here.
I'm going to check it out and figure out how to do it.
Thanks!
See if you can access from my links, here is some PDFs from my Google shared docs folder..
Homemade wire lugs..
Click HERE
My TT Rebuild PDF..
HERE
My 8700W gen sound test video (for those folks thinking the muffler is where the sound comes from)
HERE
If you can open up my PDF and video links, pix files will be no issue..
You do not "need" to use Google pix for sharing pictures either.. Just use the Google drive and set for sharing..
May take a couple of tries to get it working as it isn't 100% obvious on how to do it.. Thought about making a doc to show how it is done but by the time I would get it posted Google would most likely have changed how to set it up..
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Nov 18, 2025
