- 2oldmanExplorer II
BradW wrote:
Which one? I didn't know there were any 'big names' in that business. :)
Thanks, but I'm going with a big name photo hosting site this time. Gdetrailer wrote:
2oldman wrote:
BobsYourUncle wrote:
See if you can display a google image here.
I'm going to check it out and figure out how to do it.
Thanks!
See if you can access from my links, here is some PDFs from my Google shared docs folder..
Homemade wire lugs..
Click HERE
My TT Rebuild PDF..
HERE
My 8700W gen sound test video (for those folks thinking the muffler is where the sound comes from)
HERE
If you can open up my PDF and video links, pix files will be no issue..
You do not "need" to use Google pix for sharing pictures either.. Just use the Google drive and set for sharing..
May take a couple of tries to get it working as it isn't 100% obvious on how to do it.. Thought about making a doc to show how it is done but by the time I would get it posted Google would most likely have changed how to set it up..
Yes, your links all work fine.
Thanks for the pointers.- BradWExplorer II
Gdetrailer wrote:
Actually, you can use the RV.net photo posting is great for other websites..
You can copy entire URL from that app, then remove the RV.net forum specific parts. which is the beginning part where you see the brackets..
So what you would see as " bracket IMG bracket" at the beginning and " bracket /img bracket " at the end you can remove and now you have a photo usable on other websites.
So, a jpg I posted using the RV.net app would now look like this once I remove the RV.net formating..
https://i.imgur.com/cc5OEwzl.jpg
And it does work just by dropping that address above into your browser..
Thanks, but that wouldn't work for me; too slow, too cumbersome. That might work for a photo or two, but I sometimes batch upload 100's of photos at one time. I also need to be able to set up albums with specific photos in it. Plus, rv.net could cut that off the ability to post photos on their web site on another forum at any time. Most forums which host photos already do that. - BradWExplorer II
2oldman wrote:
BradW wrote:
ImageEvent should do it for you.
I need an easy solution that works on any forum, not just the rv.net forum.
Thanks, but I'm going with a big name photo hosting site this time. - GdetrailerExplorer III
:R
Read the TOS..
HERE
"ImageEvent provides space for Member Albums but makes no implied or express warranties about the reliability of these albums. ImageEvent is not responsible for any damage caused by loss of access to, or deletion or alteration of Member albums; individual Members are responsible for monitoring and creating backups of their albums.
DISCLAIMER
YOUR USE OF THE ImageEvent SERVICE, INCLUDING ANY MATERIALS, DATA OR INFORMATION POSTED, SUBMITTED, DOWNLOADED OR OTHERWISE OBTAINED THROUGH THE ImageEvent SERVICE, IS AT YOUR OWN RISK. THE ImageEvent SERVICE IS NEITHER DESIGNED NOR INTENDED TO BE USED AS A DISASTER RECOVERY FACILITY OR AS AN EMERGENCY DATA STORAGE FACILITY. ALTHOUGH ImageEvent TAKES REASONABLE PRECAUTIONS TO PRESERVE AND PROTECT THE MATERIAL YOU MAY UPLOAD TO THE ImageEvent SERVICE, YOU SHOULD NOT RELY ON THE ImageEvent SERVICE AS YOUR ONLY SOURCE FOR THE MATERIAL YOU PROVIDE. YOU SHOULD KEEP YOUR OWN BACKUP COPIES OF ALL MATERIALS YOU MAY USE, OR ALLOW OTHERS TO USE, IN CONNECTION WITH THE ImageEvent SERVICE, INCLUDING MATERIALS POSTED OR SUBMITTED TO THE ImageEvent SERVICE.
THE OPERATION OF THE ImageEvent SERVICE MAY BE AFFECTED BY NUMEROUS FACTORS BEYOND ImageEvent'S CONTROL. THE OPERATION OF THE ImageEvent SERVICE MAY NOT BE CONTINUOUS OR UNINTERRUPTED OR SECURE. SECURITY AND PRIVACY RISKS CANNOT BE ELIMINATED. PASSWORD PROTECTION MAY NOT PREVENT UNAUTHORIZED ACCESS TO MATERIALS YOU MAY USE OR ALLOW OTHER PERSONS TO USE IN CONNECTION WITH THE ImageEvent SERVICE, INCLUDING MATERIALS POSTED OR SUBMITTED TO THE ImageEvent SERVICE.
THE ImageEvent SERVICE IS PROVIDED ON AN "AS IS" AND "AS AVAILABLE" BASIS, AND WITHOUT ANY REPRESENTATIONS, WARRANTIES OR CONDITIONS OF ANY KIND, WHETHER EXPRESS OR IMPLIED, AND INCLUDING WITHOUT LIMITATION IMPLIED WARRANTIES OF TITLE, NON-INFRINGEMENT, MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, PERFORMANCE, OR DURABILITY, ALL OF WHICH ARE HEREBY DISCLAIMED BY ImageEvent AND ITS SERVICE PROVIDERS TO THE FULLEST EXTENT PERMITTED BY LAW. "
Just because you have had no problem with your storage, doesn't mean it will be available or work forever..
Chances are, it too will eventually fall.. - GdetrailerExplorer III
BradW wrote:
AsheGuy wrote:
In spite of the many complicated solutions suggested here for putting a photo in a post, it's not that complicated. The simplest way is to use the RV.NET provided Photo Post & Upload website that properly sizes the photo and provides a link to copy and past here.
With fototime, I could just right click on the photo and it copied a link to my clipboard that I could paste anywhere. I could post the image or a link to the image. I could also create albums containing photos for a certain topic, like a vacation and then easily copy and paste the link to the album anywhere.
Here is that link setup as a clickable link HERE
Those photos are hosted on imgur.com and supposedly (I have not tried it) you are supposed to be able to manage them.. You could even sign up for imgur for your own account..
https://imgurinc.com/about - 2oldmanExplorer II
I need an easy solution that works on any forum, not just the rv.net forum. - BradWExplorer II
With fototime, I could just right click on the photo and it copied a link to my clipboard that I could paste anywhere. I could post the image or a link to the image. I could also create albums containing photos for a certain topic, like a vacation and then easily copy and paste the link to the album anywhere. - BradWExplorer II
Gdetrailer wrote:
Should also note, you missed filling in the height when you attempted to post the photo, you will need to fill in both height and width when you use that option.
You don't have to enter both height and width. You can just enter the width you want and the rv.net software will set the height for you based on the original h/w ratio. - GdetrailerExplorer III
2oldman wrote:
Seems pretty complicated.. for now. I put a picture on ImageEvent, I grab the url, paste, done.
I will add, it does "seem complicated" to work things like this out, but as the OP and myself have found out, photo hosting sites DO disappear regardless of being a "paid for site" or a "free site"..
I am glad what you have and use works and it will work great up to the point into the owners decide that they are not making enough money to continue operations, sell out, change the TOS or just plain leave town without a trace and you have no more access to your online photos and all of your links now go nowhere..
That IS the problem with online storage, you don't own the storage facility, equipment or connections, someone else does, someone else foots the bills to keep the servers powered and connected 24/7 and when the cost of operations exceeds their "income" from customers and or ads they face a decision to foot the extra cost, raise prices, restrict/reduce features or just completely shut down and cease operations.
Anyone can startup their own file hosting site, but it takes money to buy or rent equipment and storage space, it costs money for the high speed and the amount of concurrent connections that the ISP will allow, costs money to buy and maintain domain names, costs money to get customers, costs money to service the customers when something goes wrong.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 11, 2025
