rk911
Apr 18, 2014Explorer
I used both the smaller "passport" drives and the 'MyBook' desktop drives from WD. the 'passport' serves as a travel drive with our laptop as well as our emergency backup drive that is stored in our safe deposit box. I use the 'MyBook' drives for home use.
words of caution. the 'passport' drives work well with the supplied USB cord. if you try to use it with a longer cord it may not work at all. and be sure you select a drive to match your USB port. many/most but not all USB drives are backwards compatible. that is a drive that is advertised as USB3 compliant likely will work on a USB2 port...just be sure before you buy.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
