Luke_Porter's avatar
Luke_Porter
AT&T Fiber
What kind of wire does AT&T Fiber come into the house on?
  • Having "fiber" in your house is not very useful as you likely will not own anything you can plug it into ! I hope that the installation would include a router/switch with at least 8 Gigabit Ethernet (1000Base-T, backward compatible with 100Base-T) ports. Both use the same RJ45 plugs.
    To achieve 1000Base-T throughput, you should purchase good quality, pre-made, CAT-5e or CAT-6 cables.
    gkainz wrote:
    last comment - here's a better video youtube AT&T into the house
    Yes, much better ! The ONT converts fiber to copper. You supply you own switch/router.
  • I would be surprised if they actually did a fiber drop into each house. I've pinged a few of my co-workers who may know exactly where they drop from fiber to cable in each circuit. Will update if/when I hear back.
    Edit - talked to some co-workers and they said that they usually DO run a fiber drop to the house. At the DMARC box (outside the house), it converts to CAT-5, CAT-6 (or coax sometimes) and then that medium continues inside the house. You can open the DMARC box and verify what you have.
    However, I just found this Youtube AT&T gigabit installation that shows fiber continuing into the house ... so I guess I'll just shut up now! :D
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
