Dutch_12078
Mar 19, 2017Explorer III
TenOC wrote:
Since USB is 5Volts and a car is 12 Volts I assume he need the "Using USB power adapter, posting on how to make one in the other thread, can also be purchased on eBay."
This $6 USB cable is the one the fellow selling them on eBay is using connected to this $7 female ODB2 connector. The USB cable has the 5VDC to 12VDC converter chip built into the USB plug. The only other items needed are a bit of solder and some heat shrink tubing. A soldering iron, wire cutter/stripper, and a multi-meter are the tools used.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Aug 30, 2026
