chuckbear
Mar 27, 2017Explorer
TenOC wrote:chuckbear wrote:
Pin 16 is the positive connector and pin 4 is the ground. That's all you need. Chuck
I twisted #4 Chassis ground and #5 Signal ground together before connecting to 12 negative. It works.
It may work OK but the signal ground is not needed. This is only to prevent interference on certain electronics and the Mobley does not have that problem. I would not connect any pins that aren't needed to power the device, not knowing how it will affect it later on. Chuck
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Aug 30, 2026
