MrWizard
Apr 18, 2017Moderator
DiskDoctr wrote:MrWizard wrote:
A USB power supply steps up pc USB 5v to 12v for the Mobley
Designed to plug into your pc USB , and power the Mobley directly from the pc
To power the Mobley from 120vac buy the 120v adapter
The ad is saying do not use the USB adapter with a cheap 120vac to USB charge adapter
Use it Only with your pc
Best guess is the converter chip in the USB to 12v adapter is sensitive to voltage, and some of the cheap adapters are not well regulated
They worth with phones because phones have built in charge regulation to control the voltage
If you look at a cell phones battery yo will see it is not 5v
It is usually 3.7 volt, and the phone circuits keep the applied charge voltage under control
The USB adapter has no charge control circuitry
It is converting 5v to 12v
And to high an input voltage could damage it
It also said problems with charging from a computer USB.
That makes me think the amps are the problem? We've run into similar issues with charging tablets. Need to have at least 2.1 amps per port, not the smaller versions.
Makes me wonder about using a 20,000 mah battery with the USB port, it if will work properly?
Also considered the 12v cigarette lighter style plug. We are going to add those plugs and USB outlets to the camper, specifically for phone charging without using the inverter.
Cell booster is already 12v, though it's 3G, maybe time to upgrade to 4G for the Mobley ;)
The wording of the cautions in the ad really have me concerned. At $40 a pop, don't want to get 12v, USB, and 120v separate adapters ;)
USB battery would really make it a nice, portable system when needed.
Are you using a router with it?
No router, and I'm using the 120v power adapter, have plugged into the same power strip as the tv and pc, which is powered by my inverter
I just turn it off at night
The phone chargers etc... Are on a different outlet same inverter
So far I've only had two devices on Wi-Fi at the same time
My pc and my laptop, DW doesn't use the internet
The tv is dumb
The Blu Ray player is smart but, I don't use it that way, my printer is Wi-Fi capable but is off more than on and I have always used usb cable , but I may change to Wi-Fi for that, and open up that USB port for another external hard drive
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Aug 28, 2026
