bob_nestor
May 12, 2017Explorer III
jackquontee wrote:magicbus wrote:
The password is on the paperwork that came with the Mobley. It also includes the info for logging in and modifying the Wi-Fi password.
Dave
The only mention made of a password (which is "attadmin")in the paperwork I received relates to turning off the Powersave feature, and after entering 192.168.1.1. I've entered the password for the wifi network on my phone, and entered the default IP address on my laptop and desktop, and neither of them work.
So, I'm still not sure what password you're referring to.
There are two passwords. One is for general connection to the Mobley and it's shown on the device itself on a sticker on the back. The other password is the attadmin password. You must first connect to the Mobley using the first password in your network connection from your computer or phone. Then you can use a web browser and open the web site 192.168.1.1 which is the Mobley itself. When it asks for a password you enter the attadmin and you're now logged into the Mobley and can do admin activities on it, such as changing the name of the service, changing the default password for network connection, changing the admin password, enabling guest access and changing the default timeout. If you make any changes it will want to reset which logs you out as admin and disconnects your from the device network wise. Then you connect back to the network device using your new service name and password.
If you forget the service name or passwords you can reset the device to factory defaults with the reset button. When you do this it restores the service name and network connection password to that which is on the label on the Mobley itself. It also resets the timeout and the admin password back to attadmin.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Aug 28, 2026
