Jbird
Jun 10, 2017Explorer
MrWizard wrote:
jbird
Just differing sensitivity and equipment
And remember your depending on the calibration of the MiFi and the Mobley to give you that signal reading number
As for the data reading
Simply watching YouTube or other video in a better quality higher resolution, because you can, because it doesn't buffer and stutter will easily double the data use
And YouTube Netflix and so forth, will send you the best quality possible unless you choose a lower resolution setting manually
Thanks Mr Wizard. So if both are 4g, one may be using more data when on the same site?
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
