delwhjr
Jun 13, 2017Explorer
Jbird wrote:
Hmm. Ive just finished comparing my MIfi (Verizon) speedtest results with Mobley,finding very little difference in the current location. Nonetheless, my Mobley data use figures are off the chart from any Ive ever had with Verizon
Data speed tests can be very misleading. Some test only the actual bits per second and do not account for actual throughput. The amount of data used can vary wildly depending on type of data sent, the number of re-sends due to drop, the amount of negotiating needed to keep connection, side channel control data and many more things that some carriers send along with your requested data. You will see more data on a stream of high definition than on low and the carrier sometimes restricts the stream in ways other than data rate.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
