Snowman9000
Jan 27, 2016Explorer
Summing up various correct replies...
Add up the watts or amps the items use.
If amps, multiply by ten to get amps at 12 volts.
If watts, divide by 12 to get amps at 12 volts.
The sum will probably be higher than what will actually be used, but anyway.
The inverter will consume additional amps, maybe it balances out with the previous over-estimate.
Let's say it is 72 watts / 12 volts = 6 amps.
For an hour, that is six amp hours.
Group 24 & 27 batteries are 85 & 105 amp hours respectively. Don't run them to empty or they won't last long. So depending on how you want to treat your battery, at 6 amps you could do 8, 12, 16 hours?
Hopefully this is good enough info.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
