RoyB's avatar
RoyB
Explorer II
Feb 25, 2017
BEST ROUTER EXTENDER TO USE
I have the ASUS RT N66U Router here in my North Room of the house and although the house is covered well with this router the outside area along the East wall of the house a little centered more to the south as well as my Camper setup which is due East of the house around 60-70 feet or so does not get real good coverage especially for steaming video..
There are too many on-line to look at and they all say they will work hehe...
My ASUS 66U has three antennas on it and also wired ports which I am currently using three of the wired ports.
I guess the extenders are really repeaters and will use one antenna to pick up the router signal and then re-transmit it out the second antenna...
I have had some cheap ones in the past but they never last very long... I used them in the kitchen window looking out over the back yard to the east...
I have 120VAC power at the trailer location and of course on the back patio area.
The dollar ranges are from $50 to $100 I guess and would like to order them from AMAZON... Of course I want one with all of the pass word protect modes...
Would like to hear from anyone that has used the extenders...
I have an overhang up under the house roof and would even like to mount something there out of the weather. Can run an simple extension almost anywhere out-of-site... Don't know if mounting one in the attic might not be a bad idea???
Perhaps it might be better to run a CAT5 Cable to the extender/repeater and not depend on it picking up WIFI mode from the router???? Have run such cables for up to 100s of feet in my work days with good results for office setups...
Roy Ken
  • If you gave cat5 in the entire house look to get a wireless access point to wire into your network it will work the best
  • RoyB wrote:
    pconroy328 wrote:
    If you've run CAT5 before then you know wired beats wireless - every hour of every day.
    I actually have CAT5 run to all of the rooms here with a patch panel back here in my so called Radio/Computer room. That would be a short run of a CAT5 extension in the kitchen to get from the wall to the East side windows where I could velcro a WIFI extender to the window glass...
    I guess those WIFI extenders have pass-word protection even if you are direct feeding using CAT5 cable... I have neighbors around me on two sides here...
    Might be a good solution for me...
    Roy Ken
    Can't speak for all extenders, but this one is password protected. I used the same password I use for my router to keep things simple.
  • RoyB's avatar
    RoyB
    Explorer II
    Roy Ken
  • If you've run CAT5 before then you know wired beats wireless - every hour of every day. :)
    That's what I've done. I've got an inexpensive TP Link wifi router that's been flashed with DD-WRT and it's wired back to the DSL modem. It's on one side of the house with the Netgear Wifi router on the other.
    I get great coverage and I think it was a $15 investment. :)
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,794 PostsLatest Activity: Mar 07, 2025
