Bill.Satellite wrote:
Since it is your plan to keep cable (good idea, most likely) and you only want satellite service 3 months per year then I would suggest Dish Network and the Pay-As-You-Go service. You can actually pay for 3 months in advance and at the end of that period the service will simply stop. No action required on your part.
As to the antenna, the picture quality will be exactly the same whether you install a Trav'ler, a ground mounted tripod or a dome style antenna like the Winegard Playmaker or the King Controls Tailgater (or any other for that matter). Where there are differences are during moisture related events (clouds, rain, dew, etc.) which are rare in AZ in the Winter. The least expensive antenna setup will be a home style antenna mounted on a good tripod. This is also the least convenient as it takes up a good deal of space while traveling and take 20-30 minutes to setup. If you only go one place for the Winter season this also makes no difference at all. This type antenna will also allow you to use any Dish receiver, DVR, or Hopper.
The dome style antennas work great as long as you only want to use 1 signal tuner receiver. The domes antenna can only "see" 1 of the 3 Dish satellites at the same time so if you have more than 1 receiver or a DVR both tuners must be watching programming coming from the same satellite and this often causes a conflict.
Hope this helps but it should give you a pretty good overview.
Thanks for the overview. Much appreciated. We normally watch TV at night and during the day when the weather is overcast, cold or raining. A DVR would be nice but not critical. It's my understanding I can use an inexpensive device like a Wally and an external hard drive to record TV. I haven't researched that much. It would also be nice to watch two different stations at once. I'm been looking at the Winegard Pathway X2 and the Carryout G2+. The 20-30 minute setup on the tripod and dish doesn't bother me ... at least not now... as long as I end up with the best TV during different weather environments. Maybe after doing it a few times I may think differently. I got the idea from other posts the automatic dome systems were a little flakey on HD and you had to mostly settle with SD. You mentioned the Playmaker. Is there an advantage with the Playmaker over the X2 or G2+, other than cost?
Also, do you have experience or good research comparing the Wally to the Dish 211z?
