BB_TX wrote:
Direct or Dish is personal opinion, and there are fans (and critics) of both. We have had Dish both at home and in the RV for many many years and happy with it. Dish does have a monthly plan you can start and stop whenever you want. Check dishformyrv.com for info.
I would go with a portable satellite antenna. For one it is cheaper than having one permanently installed on the roof. And two, if there are a lot of trees around it can usually be positioned to find a hole thru the trees to find the sats, something not so easy for a roof mount.
I have dish and bought the tailgater portable sat dish at the time.  If I had done a little more research I would have bought the Pathway 2x, which eventually I did.  The tailgater only sees the western arc which a tree in my seasonal site has grown so much in the last year that no matter where I sit the tailgater it cannot see the sats in the western arc.  The Pathway sees either the eastern arc or the western arc for a single receiver.  Now I have a clear view of the eastern arc sats.
Just something you might want to consider if you go with Dish.
