TCI's avatar
TCI
Best satellite TV for fulltime RV'er
Hey all. We know their are a few options out their but we value everyones input. Right now we do OTA or the rv parks cable. We would like a satellite service we don't have to make a annual commitment to. If we use it two months and then not for 6 months and then again for a month, we would only be responsible for the months we use it. OK, I also would like to know how the antennas you set up yourself outside compare to if we had one installed on the roof. Can I run more than 1 tv on the antenna? Looking to try to figure out all the costs.
1. Antenna 2. Service
I may be missing something so please let me know. Thank you all for your knowledge.
  • I can only speak about Dish. They have a "pause" option so that you don't pay when you aren't using it. However, there is a $5 a month charge while on pause. (beats a contract in my opinion). I have been happy with their service and customer service.
    I have two antennas. (can't speak to roof antennas, other than they can't be moved to account for trees and things; someone else will have to chime in)
    One is the Tailgater, for short stays, which I simply set out and plug in, and it finds the satellites by itself. I usually set it on one of the slides since it only weighs about 5 pounds. It will only run one TV in hi-def, but you can run a second tv in low def.
    The other antenna is a tripod antenna, that I have to set up and aim each time. It takes some getting used to and can take time, but worth it to me in the long run. I use it for long term stays, and I can run up to 3 receivers off it, all in hi-def. I have two separate wire runs from the antenna to two separate receivers. I don't use the RV wiring since I always seems to have issues when doing so (cheap cable, loose connections, etc)
    Cost for viewing depends on how many channels you want. Go to their website and check out the packages. I pay about a $100 a month for what I watch. About the cheapest package you can get is going to cost about $75 after taxes etc, and you can easily top $200 a month with lots of channels, movie channels, sports packages, etc. Up to you.
    Cost for equipment depends on what you use.
    The tailgater is about $375.
    Tripod antenna about $150.
    Another $50 for the satellite finder kit (for tripod antenna)
    Vip211 receiver is about $75. Wally receivers/Hoppers are $100 plus, I think.
    Hope this helps.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 11, 2025
