Acampingwewillg's avatar
Acampingwewillg
Explorer II
Sep 25, 2014
Better Wi Fi capture in campgrounds
OK, first things first, I'm not exactly top notch computer savy but I've been looking for devices,antenna's,what have you to provide better reception(possibly better transmission) of Wi-Fi signals in a camp setting for multiple uses. Things I've looked at......JefaTech repeater kit, Wave Wi-Fi Rogue, Wi-Fi Ranger products with umbiquiti / POE.
It appears the Ranger products are among the better choices but I'm wondering about price vs performance. We're not looking for anything more than to get on line within the RV without walking about trying to get a clear line of sight. E-mail and Web browsing is all we need. We currently don't have a cell phone that is hot spot capable but I see the Ranger products offer the switching necessary to access the signals available so that feature seems worthwhile. Anyways, just trying to get a better understanding of what's out there?
  • I have a wave wifi kit... It frikn rocks.
    So far the best wifi piece of hardware I've bought.
  • Research an EnGenus EUB9603H external Wifi adapter. They are about $20. If you need more gain (signal strength), EnG makes an external antenna, EAG2408, but I think you'll like just the ext. adapter. Getting the adapter/antenna out of the PC enclosure will do wonders for your Wifi reception. I've used this setup for years at home and while we're camping. The utility for finding the Wifi routers is easy to use too.
    quick start
  • 1775...... That sounds like a good starting point, I'll have to check it out. I understand the bandwidth restrictions with any / all campground Wi-Fi. Thank you.
  • I use a wifi range extender (wifi booster - they are called various names) from Amped Wireless. There has to be at least a weak connection to the wifi to start with. Mine needs a laptop or PC to use as a display for the device to be able to lock in the wifi signal. Since I got mine, I believe some of these don't need that. What happens is the device connects to the laptop. It then finds the signal and locks it into its memory. When you then connect with your tablet or laptop to use the wifi you are going to select the device as your wifi connection and not the campground's wifi. The unit has the campground's wifi locked in and is boosting it. I have gone from a poor wifi connection to a solid connection that does not drop. It is not increasing bandwidth. If there is a problem with too many users in the campground on the wifi at the same time it will not do much for that. But I no longer have to go outside to the office or the nearest wifi point to get a usable connection. As long as you stay in that campground - even after you turn off and unplug the booster - once you turn the booster back on the signal is still locked in to connect to. Change campgrounds and you need to do this all over again. This may or may not be what you are looking for but it has worked for me. It cost about $100 in a computer discount retailer.
  • I am currently using a pay as you go (internet on the go) device that is on the Sprint network(works less frequently that frequently). My cell is on the Verizon network but with Straight Talk there can be no tethering. Since we frequent Thousand Trail parks(need to get my monies worth)..often a trip to the Lodge provides less than stellar internet service on their network but being able to capture what little signal there is from the rv would be so much more doable that trekking over and then finding out you still can't connect.
    No doubt, a hot spot cell phone or air card would be a viable solution but for our usage, a monthly cost just doesn't seem worth it. Honestly, I can do most everything on the phone but my wife wants to use the laptop.
  • I see that many folks get a Hot Spot from Verizon and bypass the parks WiFi altogether. If I had the extra $$$ that's what I'd do.
  • You likely will not see much improvement overall. Especially for WiFi, you are at the mercy of what the campground has installed. Even if your signal strength can be increased, you will see little change in performance. That depends on the total bandwidth the CG has contracted for and how many other campers are sharing that bandwidth. Early to mid mornings are usually best - many are packing up to leave and are not on line. Evenings, especially after dark, are the worst, as everyone gets on line to browse the web or check e-mail.
    I just retired from managing part of the wifi connections for a major University, and the only way it really can be improved is if the owner contracts with a higher speed/bandwidth provider, buys more capable equipment, and install more access points. It is only the last item that you might be able to improve on by buying your own booster - but if the coverage is that bad, you can count on the fact that the CG saved money on the overall amount of traffic their connection can handle, meaning it will still be slow. Your only real alternatives are to consign yourself to "primitive" camping...or piggyback on your cell phone service to use it's Internet connection instead of the CG.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 04, 2025
