roy67ss
Feb 17, 2018Explorer
Bizarre winegard traveler problem
I am having fits trying to figure out what is wrong with my winegard travler SK7003 system. This system is for Shaw. The control box shows that it has found the 2 satellites 111 and 107. It goes thru the peaking and identifying procedure and shows the * by the satelites. The problem is, it has actually not found them. The azimuth appears to be ok but, the elevation looks to be too low. I get no signal at the receivers. All of the coax cables are good. I have even connected directly from the lnb to the receiver to verify that there is no signal. I believe it is close because the satellite strength meter option shows occasional blips of signal but nothing steady. I am using 600 and 630 receivers that are all active on my other dish.
I am very puzzled as to what the control box is finding that it thinks are the required satellites. It has me extremely puzzled. I have recalibrated the elevation and reset the box to factory settings. I will be talking to the support at Winegard on Monday but, if anyone has any suggestions, please let me know.
