ReneeG wrote:
Not sure why you quoted my comment. The portable CD player I referred to had an ear phone adaptor and was portable. It did not plug into the vehicle and was not meant to
Well, mainly because the OP of the thread was using their now gone older vehicles CD player to play their audio books. With their new vehicle, there is no CD player to play audio books on CD and was asking for alternative methods to play their audio books on CD..
So in reality, just because you used a portable CD player to play audio books it doesn't really apply here unless the OP wants a portable CD player laying on the seat or floor and some BT adapter wired up to it also.
Most vehicle manufacturers no longer provide analog aux input jacks basically relegating a portable CD or even Mp3 player now useless with out an additional analog to BT digital adapter..
Now you have added more items into the chain..
On top of that, good quality portable CD players are pretty much a thing of the past, the big name brands have pulled out of that market yrs back and the leftovers that you can buy don't last and don't track the CDs as well, leading to a lot easier to skip tracks.
That leads us to the idea of say a dedicated MP3 player with built in BT adapter, dedicated MP3 player with external BT adapter, smart phone plugged into the USB port of the radio (but this method uses the radio to "control" playback which apparently a lot of folks don't like), Smart phone linked via BT (which also uses the radio to control playback which for some reason folks are fine with???)..
All of those methods are long, long workarounds which require a bunch of expensive parts and those parts are loose and use batteries and or will need charged..
The oddity of this whole thread is folks want to use all of these other less convenient and more hassle methods to avoid the easiest and most direct method which is to rip the CDs to MP3 and copy the MP3 files to a USB thumb drive..
I kind of get it, getting MP3 files to play in correct album order can seem to be a daunting and frustrating task but once you understand that you are dealing with computer OS logic then the task gets very easy.
You have to think of the play order in terms of how a computer OS places the files in order.
Logically, it is done in numeric sequence first.
File name starting with 1 plays before file named A
File named 10 will play before 1 (yep, this is one of those OS oddities that needs to be accounted for.
To get file named 1 to play before file named 10 you must name it 01 (IE add a leading zero to the 1)
To get each album to play without them being all jumbled up (a complaint from a lot of people on this forum in the past concerning playing MP3s from USB drive), you simply put all the album files from that CD into a folder for that album (folder naming uses same logic as file names).
I should note, the same exact rules that need to be followed for USB flash drives applies to most portable MP3 players if you want success. Some portable MP3 players totally ignore folder and file name for order of play, instead they use the date and time stamp of when the folder or file was copied to the payer :h why? I don't know.
I like the fact that I don't have to build a "playlist or play lists" and if I really wanted a "mixtape" I can drop a copy of my favorite songs into folders I mark like mix1, mix2 and so on..
Audio CDs can be ripped, Windows media player has the option to rip audio CDs or you can easily find free third party programs.. I use a program that came bundled with a friends Creative MP3 player many yrs ago, program installs and works fine even on Win10.
For digital downloaded files like Audible books you will need to find a program to convert the downloaded Audible books to MP3, they are out there..
