Cloud_Dancer's avatar
Cloud_Dancer
Explorer II
Mar 17, 2020
Brand New Vizio 40 inch TV problem, HELP
I have Direct TV satellite and Spectrum ground cable. I replaced the bedroom 32 inch Samsung with a 40 inch Vizio, from Best Buy. It has 4 HDMI ports and ONE port for regular co-ax cable connector. I connect Spectrum using HDMI port and Direct using co-ax cable.
I could not make this new TV show anything on Direct TV, except NO SIGNAL. I went back and explained the problem to Best Buy. They said it would cost me $100 if they sent out a Geek techie,...OR I could have another 40 inch Vizio, in the new sealed box.
I connected the new one, with same results! I tried it with my two other Direct TV receivers, with same results. I replaced the co-ax cables, with same results,...NO SIGNAL. I connected, one by one, ALL my other TVs, total of five. They all receive Direct TV just fine.
Is this model Vizio simply not compatible with Direct TV signal?
