Tom_M1
Mar 18, 2020Explorer
Cloud Dancer, does your sat receiver have an HDMI output? If it does you should use that. Here's a picture of a basic DirecTV receiver. The coax connects to the "OUT TO TV" connector from the receiver and goes to the coax connector on your TV. Once this is connected make sure the receiver is one and do a channel scan on the TV. Your TV will find only one channel, either channel 3 or 4. This is an analog TV signal. This scan will probably take a long time because typical TVs will scan for both analog and digital channels,so wait until the scan is completely finished. It does not scan channels on your cable box which is hooked to the HDMI.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 21, 2026
