fj12ryder
Mar 18, 2020Explorer III
Cloud Dancer wrote:FWIW, my Vizio, that I have to select either "Antenna" or "Cable" also only has one coax connection. I have to change the setting on the TV depending on what I have connected to that single Coax input.fj12ryder wrote:
Just a thought because we have a Vizio on the camper, did you make sure you selected "Cable" and not "Antenna" when you selected the source? Ours has that selection and nothing happens if the cable is hooked up and you select "Antenna".
This would be such a simple solution,....if only this Vizio had more than one place to connect two(2) co-ax cables.
BTW all of this is in a BRICK House. The Dutch Star is a different subject (it's a 2003 model with the original CRT type Sony TVs).
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 21, 2026
