Cloud_Dancer
Mar 18, 2020Explorer II
Bill.Satellite wrote:
Cloud Dancer. You only need one coax input for your TV to work properly with a DirecTV receiver, assuming the DTV receiver has ONLY a coax output and that coax output reads something like Sat. Out or Out to TV. In the TV settings you should be able to select various input options like HDMI 1,HDMI 2, Antenna (or TV) and likely a couple of other options. You need to select the Antenna option (not cable) and with the DirecTV box on do a NEW Channel scan (search or similar). When it's complete it should show it found only a couple of channels (maybe only 1). Pushing the channel up/down button should get you to channel 3.0 or 4.0 which is where the DTV receiver output will be found.
On the back of this 40" Vizio model V405-G9 it has ports USB-2.0, HDMI-3, HDMI-2, HDMI-1(ARC), and one(1) CO-AX port marked CABLE/ANTENNA.
The Direct TV small receiver is model D12-100 without HDMI port.
The input options displayed in a line on the screen are: SMARTCAST, Watch Free, HDMI-1, 2 & 3 , COMP, & 1-CABLE
Yes, I know how to select the input I need.
My next step is to learn to perform the scan operation for the Direct TV channels. Thanks, I will report later.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 21, 2026
