Alan_Hepburn
Mar 18, 2020Explorer
Cloud Dancer wrote:
On the back of this 40" Vizio model V405-G9 it has ports USB-2.0, HDMI-3, HDMI-2, HDMI-1(ARC), and one(1) CO-AX port marked CABLE/ANTENNA.
Many TV sets are set up similarly: a single coax connector labelled "Cable/Ant". That means that you can attach either a cable coax or an antenna coax to that port. The next step would be to access the "Channel Scan" menu on the TV - there should be an option somewhere in that menu to select the input as either Cable or Antenna - that's where you need to select the appropriate signal source...
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 21, 2026
