Bill_Satellite
Mar 19, 2020Explorer II
Unfortunately, even if you get an HD receiver which is capable of High Def, if you are using a dome, the dome can only receive SD programming and the picture will be small and it will be cr@ppy. However, it will be a more simple setup as you just select the appropriate HDMI input. That will also allow you to connect your existing OTA TV antenna to that one coax connection, do a new channel scan and you will be able to watch all of your favorite local TV channels in FULL HD! The OTA TV is the VERY BEST TV viewing available as it is not compressed like the other options. Want to watch the Super Bowl and you have Cable or DTV or DISH? Switch to the OTA antenna for a substantially better picture!
If I read you last post correctly there appeared to be a complement in there. If so, many thanks!
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 21, 2026
