RedRocket204
Oct 01, 2014Explorer
n7bsn wrote:
QAM is the default for Cable-co's.
Most modern TVs have QAM decoders built in so they don't need decoders, unless the channel is also encrypted. I am not aware of a single "digital" TV that does not support QAM decoding.
So you only have to worry if you have an "old" analog only TV.
Although there are TVs that can be addresses by the Cable-Co to enable decryption.
Cable-Co's use QAM because it allows more "channels" to be encoded in a "channel" then 8VSB. TV Broadcasters use 8VSB because it's has better signal-to-noise and noise control.
Someone who knows what they speak of. :)
However, one slight correction...QAM is modulation where multiple channels/signals end up on the same 6 Mhz frequency versus with analog, only a single channel per 6 Mhz frequency. You can fit a lot more digital channels in QAM than analog in the same given frequency spectrum.
Also, QAM is the defacto for cable plants but is slowly changing to IP. There are many QAM/IP set top boxes now to where even QAM will start decreasing in numbers as IP takes over.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
