RoyB
Mar 24, 2016Explorer III
Most of us carry spare RG cables - Connect one of those up and plug into the cable connection at the post. Then hook the other end to back of the TV set. If that works fine then you can start running down where the problem is.
For those of us that has the standard antenna panel we have the PUSH BUTTON in the OFF position when using the cable connection and ON when we using the OTA antenna.
The TV SET also has to be set for CABLE or ANTENNA as well.
Not familiar with the antenna selector box you mentioned...
Has any of this ever worked before?
Also some campground cable connections are now running digital TV. Hopefully your TV sets are Digital Ready type TVs
Roy Ken
Roy Ken
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: Apr 30, 2026
