louiskathy's avatar
louiskathy
Can a dual band router send 2.4Ghz/ 5Ghz at the same time?
Can a dual band router send out both 2.4Ghz and 5Ghz at the same time?
I set up my network on my new ASUS 66U router... it's a dual band router. I have established SSID's on both but my internet access is not showing the 5Ghz SSID at all. (and I don't have it on "Hide".)
We share our wifi with other volunteers so I have them on the 2.4 Ghz side to send the signal across the parking area. I wanted to setup a 5Ghz for my own network in the motor home but I can't seem to figure it out.
ASUS tech support has emailed instructions but they ignore my question... "Do all the devices on the network need to have the same type of network card?" I've got computers that are from 2012 to now.
My question to them:
I tried to use the 5ghz SSID that was created when I created the SSID on the 2.4
GHz... I can't get it to work. I can't even see it on my Internet Access list.
I read something about having to change my channel to "N"... when I did that my Sony Vaio laptop had a major melt down. Blue screen of death and I had to back track and change everything back to the previous settings.
I think the problem is that my Sony VaioS series laptop from 2012 (windows 7 professional) doesn't have the correct wifi card so it can not get on the "N" channel?
In order to get on the 5ghz SSID... IF I used a wire to connect the laptop to the router... would I be able to get it to work then without causing my laptop to have a major meltdown again?
Their answer back to me:
Dear Kathy,
Thank you for choosing ASUS Customer Service.
I understand that you are facing issues with router. I profusely apologize for the inconvenience caused, I will surely help you with that.
Yes, No need to worry you can able to configure your router without issues.
In this case, I suggest you to follow below steps and check if it works:
Step 1: Open your internet browser and type '192.168.1.1/index.asp' in the address bar and press ENTER.
Step 2: Type 'admin' in the Username field and 'admin' in the Password field and select ‘Ok’. Now, you will be in your router’s Information page.
Step 3: From the Navigation Panel, go to Advanced Settings > Wireless > General Tab
Step 4: Select 2.4GHz or 5GHz as the frequency band for your wireless network.
Step 5: Assign a unique name containing up to 32 characters for your SSID (Service Set Identifier) or Network Name to identify your wireless network. Wi-Fi devices can identify and connect to the wireless network via your assigned SSID. The SSIDs on the information banner are updated once new SSIDs are saved to the settings.
Step 6: In the ‘Hide SSID’ field, select 'No' to automatically detect your SSID.
Step 7: Select 'Auto' in the Wireless Mode option.
Step 8: Select any of these Channel Bandwidths to accommodate higher transmission speeds:
(A) 20MHz (default): Select this bandwidth if you encounter some issues with your wireless connection.
(B) 40MHz: Select this bandwidth to maximize the wireless throughput.
Step 9: Select the Control Channel for your wireless router. Choose ‘Auto’ to allow the wireless router to automatically select the channel that has the least amount of interference.
Step 10: Set Authentication Method to WPA2-Personal (This option provides very strong security).
Step 11: Set WPA Encryption to AES.
Step 12: Enter 8 to 16 alphanumeric characters in the WPA Pre-shared Key. This is your SSID's password.
Step 13: Then select ‘Apply’ and reboot the router.
Aslo in this case, I suggest you to try changing the control channel of your router by following the instructions given below:
1. Please launch a browser and go to the default website of ASUS router’s settings page which is http://192.168.1.1
2. Click the button "Wireless" below the advanced settings.
3. You will see Channel bandwidth option please set it to 20/40/80 MHz.
4. Then below that you will see "Control Channel" select it and set the different channels that should be above 1 4 9.
5. Then click "Apply" and reboot the router.
Hope this helps. If you need further assistance, please get back to us and we would be happy to help.
Thank you for choosing ASUS.
Regards,
Raja R
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: May 15, 2026
