Dozer's avatar
Dozer
Can Win 8.1 make a "Smart TV" dumb?
Is it possible or just a coincidence? I went from using Windows Vista to Win 8.1 (8.1 was a clean install), the next day when I tried to use the "Smart" functions on my TV I get a msg: "Network interference has occurred please try again later."
I've rebooted everything on the network but to no avail. From my PC I can see the TV and I can run a continuous ping with no errors. When I try to re add the TV to my network (from the TV menu settings), it sees my router and is good to there but when it tries to go out to the internet it fails.
At some point in the 8.1 install it says to power on everything on your wireless network and then continue. All I thought about was my printer, the TV never occurred to me could this be my problem?
Not sure how to troubleshoot this...any suggestions?
Thanks in advance!
Dozer
  • By chance is it a Samsung TV? I have read several threads regarding them having this or a similar problem.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Theory has it that each device has a differnt MAC (Media Access something) number,, It is possible (not very but possible) that the computer and TV have the same MAC
    Theory is the ROUTER will assign an I/P Address which is UNIQUE to each device.. Sometimes it does not.. OR if you have "Hard Wired and I/P address it may assign that address when the hard assigned is turned off (Why I always assign OUTSIDE the DHCP range of my router)
    Finally the new computer will.. of course.. download UPDATES.. These can suck major bandwidth and overload your connection so the TV can not find the bandwidth to work with.. This.. self selves after a short time. How short depnds on the size of your data pipe (Bandwidth)
  • To answer your question, it was a coincidence. Merely installing Win 8.1 should not have had any effect on your Smart TV and it's ability to access it's "Smart" functions.
  • Thanks for the replies. The TV has an IP address, which I can ping with no problems.
    Makes no difference whether the PC is on or off. I thought it might be a conflict between my wireless printer and the TV so I deleted the printer all together. No help.
    Thanks in advance!
    Dozer
    Your TV just like a PC when placed on a network will need what is known as a IP address..
    Normally most PCs and other network devices are setup to automatically get a new IP from the network (router).
    While reinstalling your OS on the PC it may have been assigned the same IP address as the smart TV. This causes one of the devices to be blocked off the network.
    Turn the PC off, possibly reboot your router then turn the TV on with the PC off.. Then see if your TV can access the Internet..
    Once the TV is able to connect to the Internet then try turning the PC on.. If all goes well the PC should be assigned a new IP..
    If it fails to get a new IP then you may need to check the network card settings and make sure it is set to DHCP and not a static fixed IP..
  • Just turn off the PC and see what happens
    Sounds like something in your router settings has changed
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
