joebedford's avatar
joebedford
Nomad II
Dec 02, 2014
Cannot connect to WiFi
Sorry to start another thread on this subject so soon after the last one but I'm pulling my hair out trying to get this thing to connect.
This is DW's Dell Inspiron 1545 with Intel 5100 AGN wireless adapter.
It can see the network, it can communicate enough to know that I need a WPA passcode, but it always comes back with "Cannot connect"
Wireless has been flawless for the 5 years we've had this machine. Last week just before leaving S&B for Florida, it wouldn't connect to my home network. I tried connecting to wireless on the DSL modem - no go. Won't connect to my WiFi Ranger (wirelessly - works fine with a cable).
I've disabled AVG, windows defender and windows firewall. I've updated the drivers. No go.
I realize it's possible that the adapter has just plain failed but I'm not used to electronics failing anymore. I could get her a USB wifi stick but I'd like to know if there is anything I've missed.
Suggestions?
  • I had a similar problem with my Dell. The adapter worked but the Windows software was keeping it from fully connecting. The password had been changed on the router/wifi connection but Windows would not let me input a new password (it kept trying with the old one) and so the connection failed. I was never able to resolve the problem as we were just at the campground temporarily.
  • joebedford wrote:
    I'm sure the USB wifi stick will work. I'm wondering if there is anything else I can try with the built-in adapter?
    I have uninstalled the adapter in device manager and then let the system find it again. This has worked for me before. Just make sure you have the drivers available before you uninstall.
  • DW's computer stopped connecting to the WIFI at home. I tried everything I could think of. Finally, I decided the adapter in the computer had died and bought another. I replaced it on the mother board. (Did not want to use a stick because she only has 2 USB ports.) It STILL wouldn't connect. Finally, I discovered that there is a WIFI symbol on a key on the keyboard. I hit it, and the WIFI connected. She had accidentally hit that key and disabled the WIFI.
    Oh well, she now has a b/g/n adapter where she only had a b/g adapter before.
    ON EDIT:
    On re-reading the OP, I see that her computer can see the WIFI signals. That means this is not your problem. I am not going to delete it, however, because someone else may find it useful sometime.
    However, some networks require the MAC address to be registered in the system before allowing a computer to connect. At my house, even with the password, you won't be able to connect unless I add your MAC address to my MAC address filter. This should not be a problem on your home WIFI though. It also is not a problem if you try to connect at a McDonalds or Starbucks.
  • Take a ride to the nearest Starbucks or McDonald's and try connecting there. If it won't connect, you can pinpoint the problem to your adapter........
  • I'm sure the USB wifi stick will work. I'm wondering if there is anything else I can try with the built-in adapter?
  • The only way you can check the wireless adapter is to buy or borrow a usb stick and try it. If it works, you have the answer. You would need the stick at that point, anyway. Good luck.
