Bill_Satellite
Aug 19, 2013Explorer II
So do the testing without the Carryout as this should not have anything to do with your issue.
Connect the receiver to that TV (any TV) with a short piece of coax. You should see a very clear picture from the receiver (either pull up the menu or just watch the dancing Dish logo). If you don't have a clear picture try another TV. Now try the 311 on that TV with that coax. If everything is good with the 311 but bad with the 211 on each TV then the issue is the 211. Be sure that you are not going through any kind of a switch but running directly from the receiver to the TV. Also ensure the TV is set correctly to either channel 3 or 4 as that might be set differently on the 211 and 311.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 01, 2026
