Cloud_Dancer's avatar
Cloud_Dancer
Explorer II
Sep 04, 2013
CB Radio re SWR question...ANSWERED (update)
Back in 2003, MH came with optional CB antenna installed (no ground plane model). I installed a Cobra 29 LTD Classic radio, and as per usual didn't bother to read the manual.
It never had more than a couple of miles of range. I mostly used it as a walkie talkie, in conjunction with a handheld Radio Shack CB radio, for instructions when backing up.
Recently, after a long period of NOT using the CB, I turned it on and it would not transmit. I read the manual, and started trying to learn about tuning the antenna. I first checked the antenna for shorts and opens. Then, using the procedure as per the manual, I went through the motions of shortening and lengthening the antenna such that I finally achieved 1.5 SWR on channel 1 and 1.5 on channel 40. However, on channel 20 the SWR is "off the scale" (about minus .5).
On the road, the range of use for me is channel 9 to 19, both of which show a SWR of less than 1. In fact, the range of channels with 1 or less SWR is channel 8 through 26.
So, the main question I have is: Are these SWR readings good enough for normal operation, or is there something wrong with the antenna system?
BTW the no TX problem that I started out with was that the knob settings were messed up. I finally learned what each knob is supposed to do, and got it to work like it used to work (short range, walking distance). Now, I'd like to know the answer to my question because I now would like to optimize the TX/RX range on the highway.
Thanks
  • The problem could be more than just swr. If you don't understand swr you can't possibly tune your antenna. Your cb xmtr is 50 ohms. You need to know the resistive load of the antenna. Does it have XL or XC as part of that load? A good place to start is google K0BG. His web page has a lot of real good info on tuning mobile antennas. His info applies to all antennas not just ham antennas. You need to be able to measure the resistance and reactance of the antenna to totally understand what is happening.
  • Actually, if your range of use is 9-19, set the CB to channel 14 and tune the antenna for an SWR of 1:1. The other channels (frequencies) will deviate from 1:1 due to the wavelength of the frequencies. Unless you have an automatic tuner for the antenna, there is nothing you can do about that. I'd just optimize 14 and leave it alone. It should be acceptable for use from there.
    Jim - KC6AHF
  • I have built several antennas over the years. I would tune the CB antenna for best SWR at 27.20500Mhz (ch 20) and not mess with it from there.
    Sounds to me like you have other issues, what is the output power of the radio?
    Keep in mind technically 5watts is all that is legal for a CB. Not seeing your setup I really am not much help. Find a Ham Radio operator locally they should be able to help you out.
  • Something is wrong, just what I don't know. But be advised that SWR is not the final answer, if I position a short in a coax "just so" I can get an SWR of 1:1
    I'm not certain what the "minus" SWR really means, since SWR is a ratio and a "minus" reading is, well, frankly nonsense.
