Taxman2436's avatar
Taxman2436
Cell phone signal Booster ?
After another frustrating weekend of try to connect to the internet with my phone I am hoping someone has a recommendation for a signal booster for cellphones. I was at a campground and my cell phone service varied from 1 to 2 bars and this was not enough to upload and send a small file.
  • For my hotspots, I've been getting better performance from a MiMo configured pair of Yagi antennas than I got from a high end cell booster/repeater. I mounted them on top of my batwing OTA antenna for easy directional aiming. An 8-10 dB RSRP improvement is pretty typical so far.
  • There are 2 different types of boosters, and don't confuse them.
    *something that will pick up a wifi signal such as from a campground or other public wifi, and boost it so you have a stronger wifi signal. This will not help speed if the bandwidth is overloaded. They are often called range extenders or repeaters.
    *something (like a Weboost or other brand) that will boost a signal from a cell phone tower, so that you have better cell phone signal, and can talk without breaking up.
  • So now I am looking at the Weboost RV 65. Is that what you folks are using or do you have another recommendation?
    -Lenny
  • I really like the 65 for getting a directional antenna way up in the air and aiming it right at a cell tower.
    Here's Weboost's latest RV booster.... but it's your choice.
    Weboost Drive Reach
  • Taxman2436 wrote:
    Lwiddis wrote:
    Was there sufficient bandwidth? Other campers also trying also trying to use their phones for pictures, posts, talking, texting, surfing, streaming etc.?
    Not sure how I can measure that. I was using my cell service through the phone and not campground wifi.
    Lenny
    Here's a tool I like: Speedtest.net I use a Weboost, and it has been a game changer. I used to try to pick up local stations with an OTA TV antenna. Now we can usually find enough signal to stream from our Tablo or Plex server via the cell phone. As someone else posted, if there isn't enough bandwidth, you can't manufacture it, but a signal booster often will let you take advantage of what signal there is.
    Weboost Drive Reach
    Thanks for that. Looking at the reviews some people found that the mounting brackets for the Pole didn’t work so well, have you had that problem?
  • I have the WeBoost Drive Reach as shown in the video, plus a yagi antenna (Amazon) that I use on my own fiberglass painters pole (Lowe's).
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
