kfp673's avatar
kfp673
Explorer II
Jun 25, 2023
Cell repeater suggestions?
Hello all,
Looking for suggestions on a cell signal repeater / booster. My wife and I are both able to work from home and sometimes we work from camper. However, some spots we camp have poor cell service and we use our phones as hot spots for our laptops. This past week for example we were in the PA mountains state park and had 1 bar LTE at our site. Good enough to send emails without attachments but not for Teams/Zoom calls or large attachments. Thankfully, we know this state park well and know if we drive up the hill from the campground a bit we can get 3 bars 5G and hold calls fine. I noticed 2 campers with an expandable pole and white antenna that I assume was a cell extender. Trying not to spend a fortune since it will likely be used 2-3 times per year, but let me know if you have suggestions of repeaters that work well. Thanks!
  • as mentioned, height, antenna can make a big difference. Also while most of the boosters have an internal wifi antenna, if the signal is marginal, you really really really want the phone to be right next to the inside antenna/cradle.
    Next, the improvement in phone/text vs. data can be signficant. First they usually are on slightly different frequencies. Next the number of users has a bigger effect on data than voice.
    We have the latest weboost in our trailer, along with a omni or yagi on a tall pole. There are places where the phone will not connect to a tower w/o the booster and with the booster we get very good voice/text and very good data (not good enough for netflix, but plenty fast for we browsing) and there are other places where we have no service w/o the booster and get voice/text but marginal at best data. And then there are places where nothing works.
    And IMHO don't pay attention to "the number of bars". They are NOT a good indicator of signal quality, and the number of bars will vary based on which phone you have.
    Go into the menus and look at signal strength for voice, you want shomething around -100db or less for ok voice/text, by the time it gets to -120db your likely out of luck. Once you get to about -60db your about as good as it gets and most systems will limit power so you won't see a signal much stronger than that. also if your phone show ASU the bigger the number, the better the signal.
    Finally, just because your phone won't get any connection, does NOT mean a booster will NOT get you a useable signal, nor does getting a very weak signal on your phone insure that a booster will get you a useable signal.
    I've experienced both of the above conditions. We often travel way off the beaten path well away from cell towers. In probably 90% of the time when we have very marginal service the booster gets us useable signals. the other.... well.... cell service is NOT everywhere.
    Now if the boosters had a MIMO input....... my hotspot does.
  • routeforty wrote:
    Dutch_12078 wrote:
    I've had better overall luck getting good cell signals with a dual aimable YAGI antenna set configured as a MIMO set connected to a hotspot. The antenna set has outperformed our previous $600 booster/repeater and the WeBoost prior to that. The MIMO set was about $140.
    Sounds exactly like what we're looking for. I have some lake property for our TT but we only get 1 bar verizon. Could you maybe expound on what you have, where you got it, etc? We're slightly technologically challenged so you might have to go into a little detail if you have time. Thanks, Gary
    Here's a link to the MIMO set I used. Sorry, the price has gone up a little since. And below that is a photo of how I installed them on my batwing TV antenna, making them aimable and easily raised and lowered. I use them with either an AT&T hotspot or a Verizon (MIFI) hotspot. The 'Y' mounting bracket is something I cut from a 1/4" aluminum scrap with the straightened out factory brackets bolted to it.
    www.amazon.com/gp/product/B084GCBWTN/
    And here's the back. The red arrows are just stickers that show "up" so the condensation vent is at the bottom.
  • Dutch-thanks for the info and pictures. Going to be on the road for awhile, when we get back I'm going to look into it. Hope I can figure it out. Thanks again, Gary
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
