Duck's avatar
Duck
Computer Display
A few days after my browser was updated to IE11 I started to have display problems. Some of the colors are not correct. Some of the layouts have changed. I use Luminosity and they have a calendar that shows days that you trained filled in with blue. Not happening now. One web site that I go to the reply to and start a new thread buttons are not there, Almost like I was not signed in. I dug out a old lap top and these problems did not exist on it. Any suggestions on the problems> I did un install 11 and went back to 10.
Don
  • Press F12 key in IE11 to access developer tools. Then click "Document mode" and select 10, and check your colors. This is a virtualization of IE10, so not exactly the same.
  • When you went back to 10 did the colors return to normal? If yes, that would indicate a potential problem with IE 11. If no, a potential problem with your monitor.
    I've not heard of 11 causing problems like you describe....but I presume it is possible.
    Have you used the Chrome Browser? Many are using that now in preference to IE.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 01, 2025
