D_E_Bishop
Jul 06, 2016Explorer
Tom you are absolutely correct. T comment about when they hook up to satellite fooled me. And yes I meant RG6., which is to the best of my knowledge 75 ohm characterization. And in my opinion, my answer is among the best way to deal with a bad cable.
I had so many pieces of cable from my antenna to the B.O.M.B.s in my old rig that I couldn't pull out that I just ran a new piece from the antenna head to the B.O.M.B. The Winegard batwing pcb on the Winnie was so corroded that I had to replace the head and cut off some of the cable and put new fittings everywhere. I needed about 6" more from the power supply and gave it a little tug and it moved really easy. I guess they rand them in a groove in the roof insulation.
I have read Chris' article but sometimes the answer is not a tune up but replacement. If the equipment is okay it's easy. And he also refers to RG6 in that article. I'm not a expert on cables but isn't the difference between RG6 and RG8 in the shielding and core conductor.
Also trouble shooting coax in a motor home is a real pain for most owners.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
