Healeyman's avatar
Healeyman
COPYING files from Android to PC.
I have a Samsung S8+ with Android 8.0.0.
I want to COPY (NOT Transfer) pictures from the phone to a PC.
It used to be as easy as access the phone folder and Copy & Paste to the PC folder, but not now.
HOW can I do it?
Thanks,
Tim
  • On my Android phone (version 7), when I plugged in the USB cable I got a notification about it. I had to open the notification to be able to set permissions.
  • Ralph Cramden wrote:
    The latest update to Oreo, 8.0, Especially so with AT&T,is the problem. Backup to a Google account and then do a factory reset. Its a royal PITA.
    Ralph,
    I figured it out and it is WAY easier than that. It IS still Copy & Paste, but you REALLY have to dig for the proper folder.
    Thanks,
    Tim
  • GordonThree wrote:
    It should still be that easy. When you plug into the PC, you should see a USB symbol on your phone, tapit and it's likely defaulted to "charge only" or some such.
    Thanks Gordon, but MY Android version doesn't work that way.
    Tim
  • The latest update to Oreo, 8.0, Especially so with AT&T,is the problem. Backup to a Google account and then do a factory reset. Its a royal PITA.
  • It should still be that easy. When you plug into the PC, you should see a USB symbol on your phone, tapit and it's likely defaulted to "charge only" or some such. You can change it to "file transfer" ... your PC should re-detect the phone as either a removable USB or an MTP device
    after this, it's drag and drop, cut and paste, whatever.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 11, 2025
