- waynefiExplorerOn my Android phone (version 7), when I plugged in the USB cable I got a notification about it. I had to open the notification to be able to set permissions.
- HealeymanExplorer
Ralph Cramden wrote:
The latest update to Oreo, 8.0, Especially so with AT&T,is the problem. Backup to a Google account and then do a factory reset. Its a royal PITA.
Ralph,
I figured it out and it is WAY easier than that. It IS still Copy & Paste, but you REALLY have to dig for the proper folder.
Thanks,
Tim - HealeymanExplorer
GordonThree wrote:
It should still be that easy. When you plug into the PC, you should see a USB symbol on your phone, tapit and it's likely defaulted to "charge only" or some such.
Thanks Gordon, but MY Android version doesn't work that way.
Tim - Ralph_CramdenExplorer IIThe latest update to Oreo, 8.0, Especially so with AT&T,is the problem. Backup to a Google account and then do a factory reset. Its a royal PITA.
- GordonThreeExplorerIt should still be that easy. When you plug into the PC, you should see a USB symbol on your phone, tapit and it's likely defaulted to "charge only" or some such. You can change it to "file transfer" ... your PC should re-detect the phone as either a removable USB or an MTP device
after this, it's drag and drop, cut and paste, whatever.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
